Unable to install Themes
5 replies · 5,421 views · Started 11 October 2006
Hey everyone,
I was just wondering if anyone had this problem and if so, what's the fix. I have been able to download themes for the past few days. Today I received my 2gb mem card. I stuck it in and tried to install the themes that I saved from my computer. It had started the installation process. But once it gets to the end it says, "Unable to Install." So now I'm not really sure what to do. Can someone please help???? TIA
Is the setting in menu > Tools > App. Mgr > Options > Settings > Software installation set to "All"?
dee-mo, i got the same theme problem as you, with my n71, they did work before, now they dont, anybody know how to solve the problem...
dee-mo wrote:Hey everyone,
try installing themes to your phone memory instead...they are only small files and see if that works first, you may have a corrupt or damaged mem card
