Nokia E70 Wallpaper (Full Screen)
4 replies · 6,101 views · Started 17 October 2006
How do I apply a full size wallpaper on Nokia E70?
everything I did is only in the middle....
also, does anybody know what size should the wallpaper be?
I don't think it's possible. Unless u create a theme or something like that with that as the theme wallpaper.
wallpaper is 352x416 in portrait mode but beware that when you open the flipper the wallpaper will not stretch to fit. The only way you can get auto-formatting wallpaper is to incorporate it into a theme using Carbide, which uses vector graphics that automatically resize.
To clarify, the Symbian OS is vector-based. All graphics processed as part of a theme are therefore vector-based. Wallpapers can still be non-vector (jpg etc) but will not stretch-to-fit.
