New owner (today!), couple of problems
5 replies · 2,259 views · Started 26 October 2006
Hi guys, I'd appreciate a little help (or reassurance) please. Just got my handset and the two parts of the phone have a fair bit of play in them, far more than I would expect even in a worst case scenario. The handset seems ok when the slider is open but very loose with it closed. Is this normal? Secondly, the blue flashing light keeps going for some seconds once I have pressed a button and retrieved the handset from power save mode. It then goes off. Should there be this small delay? Finally, is there any way to transfer Nokia ringtones from a N73 to the N80? I'd quite like the "calm" ringtone to use as my alarm clock tone but I can't seem to find a way of transferring it. Thanks! :icon14:
sunking101 wrote:the blue flashing light keeps going for some seconds once I have pressed a button and retrieved the handset from power save mode. It then goes off. Should there be this small delay?
It always takes man and machine several seconds to fully awake from a deep slumber 😊
No, the phone 'wakes up' pretty instantly! It's just the blue flashing light that takes a while to go off - I'm up & running before it decides to stop flashing.
Mine sometimes flashes a couple of times after it's woken up, not that this means it's okay, just that you're not alone 😊
The amount of play in the slider seems to differ from phone to phone. It can be tightened if you're inclined to start taking your new toy to pieces.
hi...
didnt know where to post this....so i m here....bought my n80 3 weeks ago and upgraded the firmware last week.....have been having some display problems.... the screen flickers sometimes and becomes distorted.....like a color negative.....n then becomes ok again......has any1 come across this issue with thier phone....??
thanx
