N80 prob. !! Plz help !!
12 replies · 3,146 views · Started 02 November 2006
Hey everyone !!
I'm having a quite huge problem right now. Why all of sudden, all my files in my Gallery-Images, videos & sounds are all gone ?! I've checked on All Files(Gallery) also nothing. However, when I checked on the File Manager, there are the pix, videos & sounds that are supposed to be on the Gallery. Also, I've checked through PC Suit...and there are actually tose files...but where they aren't in my gallery ?!
So, my question now, how on earth do I transfer those files to my Gallery ?
And, another prob, why my phone is getting slower...while there are 374mb(to be exect) space available?
Any help would be much appreciated. Thx =)
Hi Butterfly1986, im not sure what the problem is to be honest with you, but here is a few easy steps which may rectify the problem -
Use Nokia Phone Manager, to transfer all your pictures to your computer, then delete them all off your phone, once this is done transfer them all back again, and see if that works.
In regards to your other problem do you have a Taskmanager program? IE Handy Taskman, it allows you to see what is running in the background, you could try one of these (I think Trials are available) or do a soft reset/hard reset of the phone.
Cheers!
first things first, have you tried turning the phone off and on, and taking the card out and putting it back in.
i have had the files not show in the gallery before but a quick onoff sorted it.
sm1thson wrote:first things first, have you tried turning the phone off and on, and taking the card out and putting it back in.
Agree... Usually must be the first thing, because on N73 it have the same behavior.
I did try this, but still doesn't work :con?
ukmic wrote:Hi Butterfly1986, im not sure what the problem is to be honest with you, but here is a few easy steps which may rectify the problem -
Cheers!
Well, I've tried to transfer them to my computer, but then my comp did hang and also my phone. I didn't able to open the sounds folder on my phone. ANd, like everytime I use the PC Suit..then always- the mobile phone is not responding
why my phone is running *really* slow l8ly ?!😡
Do You already tried a phone reset? *#7780#. The phone returns to default settings without lose personal things inside. Maybe it works!
nj7 wrote:Do You already tried a phone reset? *#7780#. The phone returns to default settings without lose personal things inside. Maybe it works!
Ummm...but what if I forgot the Lock Code? I've a short-term memory :redface:
Butterfly, try and check if the memory card is fine...at times if the mem card is corrupt it wont work. Try using a diff mem card and see if the pics show up in gallery. If that works, its time to replace/format your mem card
~Cheers
Donezo!
I did format my phone...and lost my contacts(!!!) and also I did format my memory card. And, thank god, both of them worked! Thx guys!
