What application can i use to access Yahoo Instant Messenger? Right now i'm using mm.yahoo.com. Tried Tipic but it doesnt work for me. Any suggestions?
Tipic works just fine for Yahoo Messenger. Are u getting any particular error message when u connect? BTW, You have to use GRPS Internet access point. GPRS wap wont work (if u have been using same access point as mm.yahoo.com). Your operator should be able to help you in that.
PS: Right now we only have Tipic.
I used to have a problem with tipic regarding my UserId and Password. I emailed them and promptly they fixed it. It works fine now.
thanks! i'll try it again! 😃
kobe24, i see you're from manila. tried re-installing tipicme but i keep getting the Connection Failed:Check GPRS account on phone error. did you get this? i dont recall getting the error the last time i installed it. are you using globe?
sorry bout that. i forgot to logon
[quote="Anonymous"]i keep getting the Connection Failed:Check GPRS account on phone error. [/quote]
Hm...Classic Symptoms of wrong(Wap) access point.
my network's down. that's why i couldnt connect. 😮ops: guess i'll just have to wait. 😃
I prefer to access yahoo messanger via the WAP yahoo site, means I can use the Orange access pack, rather than the precious data in my gprs bundle that I want to keep for sending email with.
