T9 dictionary, how to change the order of the predicted words???
2 replies · 11,526 views · Started 19 November 2006
Ok so my T9 dictionary on my N73 works awesome. But 1 thing, is there a way to change the order of words that the T9 dictionary predicts?
For instance, I usually type in 2255 and "Call" is the first word that comes up because its the most common. but 1 time I typed in 2255 and because I wanted "BBJK" to come up, I "spelled" it out and put it in the dictionary of the T9 so it will be a part of the dictionary.
(BBJK is a common abbreviation i use for something)
Obviously I use the word "Call" more often but everytime I type in 2255, "BBJK" comes up first. I wanted to know if it's possible to change the order, so "Call" comes up as the first word and "BBJK", comes up as the second option?
I have done this for many words so I really need help with this feature please!
thanks!
Type 2255 on your handset, rotate through words until you get the spell option, spell call, and when you type 225 it will be back to the top of your options.
I'm also having the same issue and adding the word to the dictionary doesn't solve the issue.
If I was to back up my phone and then restored the phone's original settings or updated the firmware would this fix the problem?
