HI, i got a problem, with my N71, i installed a number of themes on the supplied 128mb mem card, and they all worked fine, then i bought a 1gb card and tried to install the same themes, and it says Unable to Install, message..any ideas..
Anything odd thing when using bigger card, is that by the app, manager it only list a few java app, not everything else that is installed..and it was not like that before..
hargs48 wrote:HI, i got a problem, with my N71, i installed a number of themes on the supplied 128mb mem card, and they all worked fine, then i bought a 1gb card and tried to install the same themes, and it says Unable to Install, message..any ideas..Anything odd thing when using bigger card, is that by the app, manager it only list a few java app, not everything else that is installed..and it was not like that before..
You probably need to format the phone to re-install themes on to your handset.
I've had to do this several time with my N73.
