I have just formated my 9210 nad now I can`t find File explorer/manager (can`t remember actual name) Can You please help me?
File manager/exporer
FileManager is not part of the ROM. You must install it. It is part of the All_Nokia_data......sis installation file.
The problem is that I can`t transport it to my 9210 via IrDA, it`s too big I guess 😞 Any other way? Please help...
[quote="A.J."]The problem is that I can`t transport it to my 9210 via IrDA, it`s too big I guess 😞 Any other way? Please help...[/quote]
You will be able to use pc suite and infared to install any sis file, no mather what size 😉
😉 I think u should try doing it the classic way via cable with pc suite...
[quote="Nosferatu"][quote="A.J."]The problem is that I can`t transport it to my 9210 via IrDA, it`s too big I guess 😞 Any other way? Please help...[/quote]
😉 I think u should try doing it the classic way via cable with pc suite...[/quote]
Nosferatu, welcome back 😊
sent a mail request to me and i will send you the file.
I agreed what is said by Nosferatu..... Using cable.... Is a good way.... 😃
I had the same problem before I bought the MMC reader, back then the only way to connect my phone to my laptop is through infrared, if you dont want to buy an MMC reader you're gona have to keep on trying... youll be able to transfer it eventually... 😃
