Tom Tom problems
0 replies · 6,162 views · Started 29 November 2006
I'm really beat on this. I have Tom Tom 6 which I wish to install on my W950i. I can't use the SE install option on the SE PC suite. So I've copied all files to the memory manually. When I remove the data cable from the phone, after a few seconds I get the 'install app' message. I select install, select yes on the security warning (this program may not be compatible with your phone) but nothing happens. It won't install.
The W950i is on the Orange network. Anyone have a clue as to what the problem may be?
