Well I found a 'log' file to do with MMS's ... 672kb in the USER memory [shock horror 😮 ] called mmss.txt ... I had just uninstall SeleQ and installed FExlporer and was trying it out [smaller, better free'er] And was sifting thru thinkin - that went ages ago, sorta cleaning up - and i went from 600kb free to 1.4mb!!!! And thats not deletin any apps! wow! Thats over double - anyway this was biggest single file!!! Seek and destroy is what I say! [Woohoo 600kb to 1.4mb]
WOW!!! Clear LOADS of mem!
Could u give us the path of the file zipper
[quote="sanjay2402"]Could u give us the path of the file zipper[/quote]
I wud av put it if i rememberd it sorry - i think it was two files deep from C: IE C\LOGS\MMS [That MIGHT have been it] Its a .txt so u can searh
path to file would be nice? 😃
And does your phone still boot 😃
[quote="JyriK"]path to file would be nice? 😃
[/quote]
Heads Up ^^^
[quote="JyriK"]
[/quote]
Yep 😊
If either you two find the dir please place it here ASAP for reference save others asking
No such file on my phone. :-?
same, no such file
no such file on my phone either 😞
Only 3 *.txt files in my phone, max size 69 bytes (thanks to "Find" operation of eFileManager 8) )
same here!! or we should use file explorer instead of SeleQ ?? ( just a thought )
I dont think u will ever find the file.
670kb of .txt file would be big enough to accomodate a encycloepedia. May be zipper was having a unnaturally high usage of phone that bloated the log to those figures. or..well.. 8) .
I should admit i have'nt tried finding it though, since i dont have my phone with me (NSC) :-?
Well here is the culprit file in question - 668kb!
[quote="Zipper"]Well here is the culprit file in question - 668kb![/quote]
Well it wont attach the .txt file for some reason... Well its big an orrid!
Its too big to be attached, but zip it up first.
Wow - thats wot i call zipping! 668k down to 58k!
how in the world did you do that???
Thats quite normal compression ratio with that kind of txt file. 😃
If you have any comments regarding the MMSS text file as posted above Please feel free to post um!
That seems to be some kind of error/debug log 😃
But where is the file.I send loads of mms so expect file will be quite large.Thanks
[quote="wannyondeathrow"]But where is the file.I send loads of mms so expect file will be quite large.Thanks[/quote]
Its a .txt - Search for *.txt - called MMSS - I think its in C\log\[something] --- Dont know for sure
And BTW i send TONS of MMS
Could not find anything like this, either. Maybe it is version related? What s/w version do you have?
[quote="petran"]Could not find anything like this, either. Maybe it is version related? What s/w version do you have?[/quote]
Im on V4.36
[quote="Zipper"]Im on V4.36[/quote]This may make sense.. I'm on 3.16.
[quote="petran"][quote="Zipper"]Im on V4.36[/quote]This may make sense.. I'm on 3.16.[/quote]
me too :roll:
me ive got 3.12 and could not find this file also...
Maybe it is Version-related...
don't have the text file either (v3.12)
Could be that they have left some debug code in v4.36. That could be a pain as I notice it produced that much data in 7 days.
Anyone else with 4.36 get it??
SO what is the veridct?I have never sentan mms yetso I guess my log is probably zero ....right?
[quote="Zipper"][quote="petran"]Could not find anything like this, either. Maybe it is version related? What s/w version do you have?[/quote]
Im on V4.36[/quote]
Where have you gotten that SW from? Never heard of that version before...
