Hi! Does anyone have the same problem? Everytime i try to use my N73 as a mass storage device (using cable connection) i get an error message saying that there is an application in use that can't close . I looked thru all the apps but can't seem to find which one is open. BTW this only happened after i upgraded my firmware.
Thanks!
Z
In the "Messaging" app, are you messages stored in phone memory or the memory card?
Have you installed the "SMS Accellerator" fix on your N73?
Phone memory selected for messages and yes, sms accelerator is installed. Should i reinstall the sms accelerator?
Thanks!
make sure that the theme u are using is installed on the phone mem not the mem card...
Or anew card has been inserted, and not all SW runs. Come of then keep on "install process". The only way, is remove that programs, and install again with PCSuite.
Which firmware are you running?
If you're on the ME variant, then its the music player thats keeping "hold" of the memory card, you need to shut that application down first.
i upgraded my firmware about 3 weeks ago. anyway i'l try shutting down some apps
thanks
try to back up your phone then do a hard reset.. i had a different set of problems after upgrading my N73 to ME firmware, but after restoring the factory settings.. Almost everything worked pretty well now on my ME (well, except for my alarm clock which doesn'y alert me if the unit is off)..
