How to restore contacts database.cdb back to c drive
9 replies · 3,572 views · Started 14 December 2002
Could anyone help me How to restore contacts database.cdb back to C drive. I want to restore only the contacts not the entire C drive
Thanks !!
[quote="TheSpecialBoy"]You must replace c:system\Data contacts.cdb or whatever to c:system\data\ databaseYouWantToReplace.cdb[/quote]
Thnaks Special boy!! But sorry I could not do it.See my original c drive has folder contacts.cdb and backup ( on my PC) also has folder contacts.cdb. But when i try to replace this to C drive it says some error.
Do u know what seems the problem or maybe I am not doing the tright way.
Thanks :roll:
[quote="Anonymous"][quote="TheSpecialBoy"]You must replace c:system\Data contacts.cdb or whatever to c:system\data\ databaseYouWantToReplace.cdb[/quote]
Thanks :roll:[/quote]
Well... Here's a little "OLD SKOOL" trick:
1. make a "Backup to memorycard" in File Manager menu...
2. go into the "backup" folder in your memorycard and delete the item that u dont want to restore...
3. now replace the "contacts.cdb" in the "backup" folder with the one u want to restore...
4. Finally... do the "Restore from memorycard" in File Manager menu...
😉 Now u will have the desired contacts installed...
USE MULTI READER WRITER
Every 9210 user must have one.
Second method.
copy database.cdb to C drive with
reading it on your mmc from backup and paste this in c/system/data/contacts.cdb
With this method you do not have to restore
[quote="Willem"]USE MULTI READER WRITER
Second method.
With this method you do not have to restore[/quote]
Hey I tried I try to copy the contacts.cdb from the backup and paste in c/system/data/contacts.cdb but it always says: Target file communicator/system/contacts.cdb is in use and when I retry its the same. Well its been 5 days trying to get my contacts back.
Donno if i will be able to do or loose my 450 contacts 😞
you can only do this multi reader and windows of your pc
procedure: pute mmc in reader and the rest is playing with windows
mmc in 9210 etc
[quote="Ginzy9210"][quote="Willem"]USE MULTI READER WRITER
Second method.
Donno if i will be able to do or loose my 450 contacts 😞[/quote]
What I do:
I stand ready to copy the file.
I use FileManager to start a backup session
It will state "Closing apps"
once it said this you can copy the contacts.db to where ever you want.(I used the standard 9210 from desktop browser (the one included in pcsuite))
After this just stop the backup and delete the files it already backedup
Thankyou Dazler,Willem,Nosfratu and the special boy to help me solve this problem. I really appreciate.
:angel: :bday: :P
