hi mates,what is the best program? Seleq or Handy File?
What's best? 😉
What's best? 😉
SeleQ by a LONG shot!! Much better
SeleQ, better. But HFile is smaller in size.
Yes definitely SeleQ,especially now when they have reduce its size by making Unilingual versions of the app.
[quote="GhostDog"]Yes definitely SeleQ,especially now when they have reduce its size by making Unilingual versions of the app.[/quote]
So how big is the multi lingual and the unilingual [use your imagination on the spelling]
And Ive just bought it - will my registration key work with all SeleQs that I install or do i have to leave the one i have on?
It probably works with all verison of SeleQ.
The unilingual one is the one with an "i" in the end of the name.
Like SeleQ 1.50i
I prefer SELEQ.
yup it works with all seleQs. the multilingual is around 370kb, while the enlgish seleQ is only 189 kb! big difference ei. 😃
cous Sinister, it's SeleQ hands down!!! 😃
never used ne1 of them. where to these come in use neways ? ? ? 😊
File Managers, Setting of logo...the likes man. Read on through the forums and you'll know you need it too. 😊
check out these sites for more info:
SeleQ:
http://www.ximplify.com/
Efileman:
http://www.psiloc.com/
8)
Compare to the rest of the appl. I perfer SeleQ. It's better and more feature. I rate a 9/10
SeleQ ! No Doubt !!
hey what about eFilemanager?? isnt that good??
it takes less space then seleQ only 89 kb or something like that
[quote="Marius"]hey what about eFilemanager?? isnt that good??
it takes less space then seleQ only 89 kb or something like that[/quote]
efile is smaller but for me its hard to use bro,seleq is easy to use. :P
SELEQ WINS!!!LOL!! :P
Get SeleQ. Since many user have praise it, even moderators too, right?
It's a good appl made in Malaysia.. not bad for a Asian Software 😃
bro how many kb efile have?? 😊
[quote="Edgedale"]Get SeleQ. Since many user have praise it, even moderators too, right?
It's a good appl made in Malaysia.. not bad for a Asian Software 😃[/quote]
not bad? SeleQ rocks!!! Asian software rocks!!!! 😃 simply the best! 8)
It will be good if we can see some more solid appl made in asian regions 😉
Hopefully some in Singapore, Phillipiness, maybe... Thailand.. maybe.. Australia?
[quote="SinisteR"][quote="Marius"]hey what about eFilemanager?? isnt that good??
SELEQ WINS!!!LOL!! :P[/quote]
Both,eFile and SeleQ are very easy to use.I dont know why SinisteR found it hard and they are both good apps.
My advice is:try them both and also try HandyFile.
Use the one which suits you best. 😊
Use the FExplorer by Domi. Its free, and uses only 20kB of precious memory.
And you can do everything you need to do with it.
+ you can uninstall torch, because in FExplorer you can set the light on.
saving that 7kB more 😃
Yes,my apologies to DOMI,great and easy to use file browser.
[quote="GhostDog"][quote="SinisteR"][quote="Marius"]hey what about eFilemanager?? isnt that good??
Use the one which suits you best. 😊[/quote]
coz im not to familiar on it sori bro. 😞
Well, I'm using SELEQ in my phone, tried both but seleq is better, efile is better than seleq in: viewing big files and cleanin up temporary files(never noticed a difference in the memory), but with SELEQ you can access system files in efile u cant, screen capturing and auto locking keypad.
So I think SELEQ is better overall.
[quote="anas7650"]Well, I'm using SELEQ in my phone, tried both but seleq is better, efile is better than seleq in: viewing big files and cleanin up temporary files(never noticed a difference in the memory), but with SELEQ you can access system files in efile u cant, screen capturing and auto locking keypad.
So I think SELEQ is better overall.[/quote]
I think you can access sytem files with eFile allso.
seleQ
is wonderfull
you can access the system files with efile,there is a option given with which you can hide the system file if you want to or not
SeleQ=more functions likescreen capturing and auto locking keypad
efile=less space 😃 89 kb if im not mistaken not much features like seleq
handyfile= no idea havent used it
like GhostDog said try them both and also try HandyFile.
didos what does you nick mean??
[quote="JyriK"]Use the FExplorer by Domi. Its free, and uses only 20kB of precious memory.
saving that 7kB more 😃[/quote]
yup, DOMI's FeXplorer!!! it doesn't get any sweeter than this. 😃
FExplorer is excellent, only 17 kb, and freeware, I think it is the best.
