Hi mates, does anyone know what this is. when you move the currsor over a folder on the main menu and press the (c) button it`ll say something along the lines of cant delet3 applicatoins 0 hidden. but if you put the cursos over the sim derectory icon and press (c) it says there are 2 visible applications an 2 hidden!!. what are the hidden applications, how do i get them what do they do, where why how when how often and other such question :P
Secret on 7650!!!
I tried that, there is only hidden files under the sim dir, maybe system files or sort of that.
@ my phone there aren't hidden icons
it says 0 hidden :P
list:
- sim direct
- info time
- service no's
- fixed dial
i think you get the hidden when your sim doesn't support one of these
[quote="willum"]@ my phone there aren't hidden icons
it says 0 hidden :P
list:
- sim direct
- info time
- service no's
- fixed dial
i think you get the hidden when your sim doesn't support one of these[/quote]
Well I just got two under sim. How did u do when u displayed yours?
What you see in the SIM folder depends on what applications or services are enabled in your SIM card.
He is right. the network provider disable some of the services.
Gideon
Same here 2 visible, 2 hidden application
nop
