Is there one available? It would be great to be able to view downloaded mpg vids from the Browser straight away.
MPEG video player for N80?
there is a free divx player (divx.com) for s60 v3. and also you can use smartmovie.
I had a bit of trouble locating the DivX player on their website so to save anyone else having to hunt for it the link is - http://mobile.divx.com/DivXPlayer_S60_3rd.sisx
Thanks for digging this file out. This Divx player can also play avi files. But unfortunately I've tried playing a 350MB film in an avi format and it�s jumpy. Is anyone else experiencing the same problem?
I have some problems with DivX for Mobile. Skipped video is one thing, but the most annoying one is audio synchronization.
Which converter software are you using? I have problems when using SUPER and MediaCoder (http://www.s60tips.com/2006/12/06/divx-player-or-realplayer/).
I am still investigating this problem. It seems I have found the cause of the problem, i.e. encoding software, but I still need some more time to make sure that everything works.
After that, I will post the result in my blog (S60Tips.com).
Antony
i followed the guide on this thread and avi play very well, from footy games (itlay france final...) to a full thomas the tank engine movie which i keep on the mobile for my son in emergency situations -
