N80 Theme problem..... Background - Menu
6 replies · 2,680 views · Started 21 December 2006
Help!
Very many of the themes I try to load appear to have missing resources.
Such as the main image in this example:
And the Menu top bar in this example:
Other themes downloaded from the same site, and installed in the same fashion, and installed to the same memory card work fine.
It's just frustrating to find a great theme, only to discover that it does not work on my phone.
Am I missing something? I'm using N80 themes, and Bluetoothing them to the phone, and installing them on the memory card. As I said, many of the themes either have the problem in the first example, or in the second.
Some like this example, have both problems.
Help anyone?
Lovat
In fact, could be the Theme... Most of themes have some kind of problem. They are not well finished. For N73, I try almost 10 themes, to find only one without any problem untill now.
Interesting, my experience is in line with yours.
I wonder if there is some kind of alternative to actually loading the theme to determine if it's working or broken.
Like can I check it somehow on my computer? (Mac)
Or is there a place to get them that only posts them if they work?
Lovat
We have a winner!
radioahead, your post with the link was an excellent response.
Not only was the theme that I wanted actually created there, but
IT WORKS!
So, a big thank you!
Watching out for those bad themes..... Lovat.
lovat wrote:We have a winner!
IT WORKS!
Hey Guys,
If u wanna N80 themes, i suggest u all try the following:
www.mobile9.com
It offers a cool range of self-created themes n videos
Check it out!!!
