Animated Gifs as a background
7 replies · 7,311 views · Started 17 December 2002
hey guys.
i got Extendedprofiles Pro the other day and u can set animated gifs as wallpapers. i tried to set these animated streetfighters gifs as my background but they play about 1 frame per sec.
any idea's how i could fix this?
and could somebody post there working animated gifs plz?
p.s some good animations and avatars here http://www.yabbse.org/avatars/index.php?cat=11
and i'm not sure if u can post this link or not but some cool ADULT animated gifs here http://www.gironet.nl/home/chatter/adult1.htm
1. Those images are set to animate slowly, get some gif editor.
2. WRONG section of forums. read first, post later. :evil:
moving to s60mm section.
And those are too large.
look for some gif animators from here:
http://www.google.com/search?hl=en&ie=UTF-8&oe=UTF-8&q=gif+animator&btnG=Google+Search
[quote="Neo_lyptic2002"]hey guys.
and i'm not sure if u can post this link or not but some cool ADULT animated gifs here http://www.gironet.nl/home/chatter/adult1.htm[/quote]
ait man! thanks for the links! 😃
try....it doest not animate in wallpaper but it animate once when i open the file in image folder....
...pls advsie... 😮ops:
[quote="monvantee"]try....it doest not animate in wallpaper but it animate once when i open the file in image folder....[/quote]
The 7650 picture viewer does not loop animations.
Do you use eProfilesPro to set that animated wallpaper?
have a question, i use eProfiles Pro i've personalized it to use a certain wav tone for calendar alarms. but when i test, it still doesnt use the wav i set. any ideas? this happening to anybody else? basically just want to find out if you have the same problem coz if you do then its might be an app problem, but if not then im doing something wrong and im going to find out what that is. 😃
any ideas will be greatly appreciated. 8)
I think i know whats your problem, for example if the general profile was activated on your phone, and you pesonalized anything in the general profile, it won't work, you must be activating another profile to personalize.
