Problems with SIP client
3 replies · 2,176 views · Started 11 January 2007
Hi all,
I am just setting up my new Nokia N80IE but have a problem.
I have set up my VOIP service butit doesn't seem to register. I don't have any Wlan here, but is it possible to register to the service with 3G just for testing?
If so, how to do that? Many thanks!
Christian_1 wrote:Hi all,
yeah, you can register via 3gp by selecting a 3gp profile at your default connection sip settings. Then you have to choose automatically registering for your sip server at the internet phone settings, only then it will connect via 3gp.. but don't forget to remove automatically registering after you tested and verified that voip works else it might cost you a lot..
Truphone works with packet data connection (3G), but i tried another sip provider and the registration failed, although it works fine with the wireless connection. Also you have to be careful with the transport type (TCP or UDP) setting.
yes read my post about N80 and FWD
http://www.allaboutsymbian.com/forum//forum/thread/55870/
I have managed to with the help from people in this fourm to get mine registered
