can some1 please post the configuration for N80IE and FWD. I cant seem to get to work.
right now...here is my config
Tools---Settings---connection---Access point (put in all the configuration)
Tools---Settings---connection---SIP settings
FWD (status :registeration failed)
Prof name: FWD
Service profile IETF
Default access point: Home
Public user name: None
User compression: NO
Registration:always on
Use security:No
Proxy server settings
Proxy serv address:SIP:fwd.pulver.com
Realm:none
user name:myusernumber
password:mypass
allow loose routing:yes
transport type: auto
port:5060
Registrar server:
almost same as the obove
registrar serv addre:sip:fwdnat.pulver.com
realm:none
user name:same
pass:same
port :5082
thanks
FWD can be setup to be used on your handset!
Profile Name: FWD
Service Profile: IETF
Default Access Point: Home
Public User Name: [email][email protected][/email]
User Compression: No
Registration: always on
Use Security: No
Proxy server:
Proxy Server Address: fwdnat.pulver.com
Realm: fwdnat.pulver.com
User Name: yourusernumber
Password: yourpassword
Allow Loose Routing: yes
Transport Type: UDP
Port:5060
Registrar server:
Registrar Server Address: fwd.pulver.com
Transport Type: UDP
Port :5060
I tried this config but the phone wont register.
would you confirm the proxy server port...are you sure it is 5060. I checked the fwd website and it says the port is 5082...I tried that too..but it wont work...any other ideas
thanks again...at least I moved from registeration failed to NOT REGISTERED.
muheeb wrote:I tried this config but the phone wont register. would you confirm the proxy server port...are you sure it is 5060. I checked the fwd website and it says the port is 5082...I tried that too..but it wont work...any other ideas
Hang on I have double checked and the above is correct!
Re-check everything!
fwdnat2.pulver.com is 5082 as there are two of them, fwdnat.pulver.com uses 5060!
You can also try:
Proxy server:
Proxy Server Address: fwdnat2.pulver.com
Transport Type: UDP
Port:5082
this is from the fwd website. I will check the config and will update you.
Thanks for ur help
FWD Standard Configuration Settings:
Username: FWD Number
Password: FWD Password
Domain: fwd.pulver.com
SIP Proxy: fwd.pulver.com:5060
STUN server: stun.fwdnet.net:3478 (Phone must be STUN enabled)
OR
Outbound Proxy: fwdnat.pulver.com:5082
Listen RTP Port: 8000
Listen SIP Port: 5060
acoolwelshbloke wrote:Hang on I have double checked and the above is correct!Re-check everything!
You can also try:
Proxy server:
Transport Type: UDP
Port:5082
SRC=192.168.3.131 DST=65.39.205.114 LEN=447 TOS=0x00 PREC=0x00 TTL=68 ID=59527 PROTO=UDP SPT=5060 DPT=5060 LEN=427
I see that the mobile is trying to contact the natfwd server but it does not work..it tells me registeration failed..
I fink I am gona give up....unless u have other suggestions to debug this problem.
whats anoyying is that there is no error messege or anything that would tell me what the problem is
muheeb wrote:this is from the fwd website. I will check the config and will update you.Thanks for ur help
OR
waitttttttttttttttttttttttttttttt...I was almost gona give it up
I got it...it is registered now
I changed one thing
Registrar server:
Realm: fwd.pulver.com
Transport Type: UDP
Port :5060
grrrrrrrrrrrrrrrrrrrrreat
wooooooooooooooow....
it is working now...I can dial from N80 and recieve calls..but when I tried from my IP phone calling to the N80....the call goes through but when I answer from N80..it doesnt seem to work...
is this cuz I am on the same LAN..it should not really matter...in the IP Phone...it is connecting...but it never connect
has this happened to you???
muheeb wrote:SRC=192.168.3.131 DST=65.39.205.114 LEN=447 TOS=0x00 PREC=0x00 TTL=68 ID=59527 PROTO=UDP SPT=5060 DPT=5060 LEN=427I see that the mobile is trying to contact the natfwd server but it does not work..it tells me registeration failed..
waiiiiiiiiiiiit....I almost gave up....I got it to register with the following settings
Registrar server:
Transport Type: UDP
Port :5060
now it is registered....i tried calling hte N80 from my IP phone on da same lan...it rings..but when I picked it up...the call seemed to be answered by N80 but, the IP Phone keep saying it is ringing and not connected to the N80....has this happened to you?
Hello,
I am also going to try this out now. I have tried other providers using the 3GP profile, but it doesn't want to register. Have you got a 3G card? Would you mind trying registering to FWD through that and see if it works? many thanks!
what is the 3G card???
I tried changing the prof provider to 3GP nokia...and it registers...
anywayz,,,,I dont think N80IE sip client would work with FWD...it registers..but there is no connection when you call...
the call gets through..it rings at the other side...and when picked up..nothing happens...no connection established..
if anyone has N80IE working with FWD....please let me know as I am returning N80 back to the store..
thanks yall for ur help
Christian_1 wrote:Hello,
Hello,
Well, sorry for not being clear. i meant using your 3G connection.
I have been trying to set FWD up as well as some of my other providers but I am giving up now. I have also had some crashes with the phone so I am returning it to the store as well...
Many thanks for your help as well!
