P990i; a hopeless, buggy product
5 replies · 3,225 views · Started 15 January 2007
In case you consider buying the P990i, I would strongly recommend you wait until software and firmware have been debugged which may take years. Unless you want to call SE tech sup daily and get useless answers.
PC synchronization is unstable and conflicting with many other standard sw.
Bluetooth works only with selected, recommended SE devices probably tweaked to work with the P990i.
Just a nightmare and I give-up. I'm returning this piece of crap.
No smartass, its MY EXPERIENCE, and if you have half a brain, you check other forum and check users reactions to new firmware!!!
I would agree that the latest firmware is mostly better and more stable, but...
My Wireless LAN connection was previously working with 128bit WEP encryption no longer works having loaded the latest f/w.:frown:
