Ask any N95 questions - I'll do my best to answer. (NOTE: old thread.)
798 replies · 293,087 views · Started 24 January 2007
Thanks Rafe.
1. Where are the maps for GPS and how it works? Who is the provider of that maps, Navigon or Teleatlas? For what you said, is kind Wayfinder, with data connection and search on-line for maps? Is a free service or a pay one?
2. Battery life? Like N80, I suppose!
3. Photo quality, any improvements, or only more pixels?
1. Can the inbuilt GPS work with other SW like TomTom, Route66 etc ?
2. Battery life under normal usage (calls, music, browsing, taking pictures/videos) - I don't keep my phone on the drawer 😉
3. How sensitive is the WiFi, does it work at 50-80 meters from the router ?
4. How muck is the price without contract ?
5. Can the music keys be assigned to OggPlayer ?
nj7 wrote:Thanks Rafe.
1. The data comes from TeleAtlas. Yes it is like Wayfinder and other GPS software. Maps and toute planning happen over the air (so you may want a decent data plan, though it does cache stuff locally too). The service is free (outside of operator data charges.
2. Battery life - too early too tell, but was pleasant surprised how well it did when I had eveything going for some time (Bluetooth, WLAN, GPRS (on and off) and GPS). We'll see, but yes I think its a charge every night device.
ratza wrote:1. Can the inbuilt GPS work with other SW like TomTom, Route66 etc ?
1. Yes if they use the S60 location APIs. However I imagine the third party software may need to do some tweaks for feature pack 1 and to support the GPS. In summary its accessible to third parties, not sure if it works now. Will try and check this.
2. See above.
3. WiFi seems good so far. Will test this more later.
4. Around 550 Euro. Thats �360 approx.
5. Haven't tested that yet, but probably not without third party software.
Thanks for the preview Rafe... few more questions for you:
How much free RAM is there on start up?
How is the keypad compared to the fab one on the N93?
Do you think the internal GPS receiver is any less powerful than a standard external GPS?
What's the firmware version?
I presume the remote control has a standard headphone socket?
thanks
Neil
Simple question:
Any chance the N95 supports or will support Blackberry push email functionality?
I know it's greedy to want it cuz the phone does everything else.
But I'd rather have this than the E70, but I need the email functionality so...
Does the SIP client on this phone allow you to configure STUN or other NAT traversal protocols from the interface or is it all hidden as on the N80IE?
If the phone comes with a seperate 3.5mm jack for the audio can we assume that this is a mini-USB device rather than a Pop Port one?
And a bit trivial I know but is there a sensible door on the microUSB slot or is it another flappy bit of plastic like on the N80? For that matter what's the build quality like in general... is there much play in the slide? Does it feel plasticy or is it a bit more robust?
Can you use the FM radio without plugging in the headset cable first?
What kind of microSD do you get with the phone?
Then a more important question:
- Hows the shutterlag of the camera normal and night mode? And how is the flash, is it still blue, like on the N70 or a real white flash (btw shutterlag from N70 is really slow)
- What about the interface? Is it still a bit slow like the other symbian devices. I mean when you boot up the phone and you press the menu key it takes a while to show the grid (can you also choose for a list view of the icons?)
Those are the question for know, when I have more question I know where to find you friend
let us know
greetz 😊
What is the screen like-how does it compare to the N93 screen, I have concerned at QVGA on such a large screen size?
What is the keyboard like to use? I had hand to send my N73 back because I found the keypad too painful to use. I have had no such issues with the N80 or N93 but I am slightly concerned by the N95 keypad as it looks a bit like the cramped N73 keypad.
Seems like a good price much, much lower than I paid for my N93. With UK tax I suppose it will be £400 or so when it first appears.
Thanks for answering my questions. I am concerned that you say we will see it on contract first & that it will be while before we see it SIM free in the UK as both my contracts are not due for an upgrade for sometime. I thought when a phone appeared SIM free had no relation to when it appeared on contract?
Hello.
What happens when you launch "Camera" application from menu in landscape mode, when the 5MP shutter is closed? Could you please make a screeshot of such situation please?
Is there any information that N95 may support Blackberry connect ?
Can you check that by installing the Blackberry connect client from Nokia ?
h**p://vvv.businesssoftware.nokia.com/blackberry_downloads.php
It's just a hope ....
Thank You very much !
I have heard that the N95 will not be able to use the 3g network in the US, however, will it still be able to use the EDGE (EGRPS) network in the US? It may not be as fast as 3G, but it's better than nothing! Does anyone know?
Thanks in advance.
Crumbles wrote:I have heard that the N95 will not be able to use the 3g network in the US, however, will it still be able to use the EDGE (EGRPS) network in the US? It may not be as fast as 3G, but it's better than nothing! Does anyone know?
Thanks in advance.
As far as I know the N95 is not designed for use in the US nor will it be released in the US. Apparently the US will get a phone 'like' the N95 at some point this year.
Super Chimp wrote:As far as I know the N95 is not designed for use in the US nor will it be released in the US. Apparently the US will get a phone 'like' the N95 at some point this year.
Yes, we all know the N95 wasn't made for the US. That doesn't mean it won't work here on our networks. Hence the phone using 850Mhz. The N95 also says it supports EGPRS (EDGE,) so, what I'm asking, is can it use the EDGE in the US.
Does anyone else who knows what they are talking about have the answer?
I think I read somewhere that the N95 would come with a built-in GPS-A rather than the standard GPS. Is this true, and if so when can this version be expected to be released?
Good job the FAQ! We post the questions and you post the answers! Good idea and simple to read:icon14:
Crumbles wrote:Yes, we all know the N95 wasn't made for the US. That doesn't mean it won't work here on our networks. Hence the phone using 850Mhz. The N95 also says it supports EGPRS (EDGE,) so, what I'm asking, is can it use the EDGE in the US.
Rather than being so rude why don't you show some patience & see if Rafe answers your question!
I've now answered this but to avoid any more problems 😉 the answer is yes it will work.
Hi
Just a question about the N95 keyboard.
When the phone is landscape orientation and, for istance, I'm using the browser and I need to input same information, may I open the keyboard and use it?
Whta's happen, the orientation turn to portrait or it is possible keep landscape on? Is there a "virtual" keyboard ?
Thanks for your reply.
U.Amadei
afaik, when sliding up to gain access to the keypad the phone automatically switches to portrait mode so you can read what you're typing. since there's no touchscreen a virtual keyboard makes no sense.
LosOutlandos wrote:afaik, when sliding up to gain access to the keypad the phone automatically switches to portrait mode so you can read what you're typing. since there's no touchscreen a virtual keyboard makes no sense.
Yes, I known but I think It's annoying when you have to write several words.
Furthermore, the landscape is more large and more usable.
Anyway, is just to know what happen.
