4.13 upgrade
12 replies · 3,410 views · Started 08 February 2002
doess anyone know where i can download 4.13? someone told me its better than 3.62 which is what im using
Hi!
You have to go to a Nokia Service Point to upgrade to 4.13. By now 4.13 seems better than others.
Just do it User posted image
Regards
I have to agree, 4.13 looks very reliable. It also looks like they have tweaked it in a few places.
Zuber
Oh yeah, 4.13 seems to be better... I've only upgaded two days ago but I'm very impressed with this version of sw.
Hi every one
Is there any way if my 9210 does not cover the warranty how can i upgrade my nokia i got bit cheaper with warrant ones but now i dont know where to go to upgrade the mobile mine Sw is 3.18 User posted image
Sure you can upgrade the software on your own...but you would need either some very expensive equipment or a certain amount of electronics knowledge to make a flasher, and then you'd have to find a copy of the flash files somewhere User posted image
In other words, it would be cheaper (and a lot easier!) for you to send it back to a Nokia service center - it takes all of 30 minutes to upgrade your software User posted image
I bought my 9210 1 month ago and the version is 3.62 and then I'm upgrading my 9210 to 4.13 there is a problem with desk background..if I play the snowboard then i click to the desk there is a lines on the ground this problem can't fix with reinstall or format Memory card or the mobile phone ..anyone can help me to fix my problem or I must downgrade to the 3.62 again thank;s
i have v3.62 and i cald a nokia dealer and asked for v4.13 then dey say if it run good let it run and don`t changed it.
correct or not??
Doc2b wrote
"I bought my 9210 1 month ago and the version is 3.62 and then I'm upgrading my 9210 to 4.13 there is a problem with desk background..if I play the snowboard then"
Where did you get the game snowboard?
-Omar
I have 3.18 and the snowboard game leave's lines at my desk 2. But this only happend with my new background image, resetting the image erases the lines.(menu settings)
hello omar_g i found the software from nokia professional dealer in Indonesia ..then I 'm browse the internet until right now I can't fix the problem.I have a new problem again the cover sound if i open it like crack....i'm very scared and i go to the Nokia dealer and until now they can't fix already
