hi,
is there ne ways to change the theme of the 7650 besides the blue, purple and the green. i mean in 7210 it has grey orange red torqoise and all. they look very nice. is there ne software made as of yet for the 7650 ? if yea whts the name. i came across the similar software for the 9210. will that work on the 7650. is ne1 plannin to make these theme pakages
Colour Themes ?!?!?!
Could you please try to Search first before making another thread here.
And the answer is no, but I think that many people are working on that one.
And 9210 software wont work on 7650.
u can, using active desk
hey anas, i did get active desktop , now how do i change the theme colors and all. wht else can i do with active desktop as well. plz tell me step by step how to do it ?
I think if you have active desktop you can change the color themes but it still give you the default color which is green,blue and purple .. if you want red color you should get your phone software to version 4.++ (forgot the actual number), but you will loose some other colors, if your software 3.16 and below .... no additional color even if you install active desk. 😃
