Hi, does anyone know how I can start over by re-installing the operating system on my 9300?
I can't take this GPRS lag so re-boot issue anymore.
re-install OP for 9300
You don't need to reinstall the OS since this is built into ROM. The only thing you have to do is to reformat the internal memory (C: drive) (make sure you back up your files first).
To format your Communicator, reboot it and when the blue Nokia log disappears, press Ctrl+Shift+F.
Is there any option for restore factory settings except of pressing Ctrl+shift+f. bcoz this is not working in my cell.
