Can anyone tell me if there was software on allaboutsymbian.com that changed the screen viewing from portrait to landscape mode
I am certain I saw it on the site, but for the life of me cannot now find it.
go here and try it out,I got it working great on my N73,I think the app will only work on N73 and N80, does not work on my N71 and read it also does not work on E50 phones,btw the app has to be symbian signed to use it,its a time consuming process but well worth it... http://forum2.mobile-review.com//forum/thread/60631/
hargs48 wrote:go here and try it out,I got it working great on my N73,I think the app will only work on N73 and N80, does not work on my N71 and read it also does not work on E50 phones,btw the app has to be symbian signed to use it,its a time consuming process but well worth it... l]
Thanks hargs48
after many hours scouring forums I have found it, I am using a N80.
You are right at the moment it is time consuming to get it ready for install, and if you have not done it before , can be confusing. But it is all installed and appears to be working smoothly.
Any way I appreciate you taking the time to reply
toekneem wrote:Thanks hargs48
You are right at the moment it is time consuming to get it ready for install, and if you have not done it before , can be confusing. But it is all installed and appears to be working smoothly.Any way I appreciate you taking the time to reply
