I have 9210(a 9110 before that)i have had problems with it switching itself off .The cover broke and went back to Nokia and was fixed as appears the switching problem.Since i have had it back i have untold problems with the software.Nokia appear to have upgraded the softwareand several things are awol on it.I have formatted the phone and reloaded the original software that came with the phone(reg'd jan02).The main problem is when i am sent a fax the phone receives it ok but does not display on the phone front that i have had it.When the phone is opened it displays LACK OF RESOURCES'YOU HAVE' NOTE ONLY PARTLY FUNCTIONING.I then have to reboot the phone to access the fax.
I occasionallyget the following as well:-
The server has closed- MSN server-user-44
Any help in simple English would be appreciated,i am fed up returning to Nokia for the third time!
Problems 9210
I had bad problems with my 9210 and because I was fed up I bought a 9210i whitch is almost perfect! I sent my 9210 to nokia 6 times in 8 months!!!!!!!!!!!!Really bad.
I don't really have any concret solution to give you,but the most reasonable is to keep sending it to nokia untill it's under warrantee!
Hi Paul,
which firmware version are u using right now??? Is it 4.13???
😉 For more info on firmware, checkout:
http://www.allaboutsymbian.com/support/nokia92x0/guide2.php
phone now going back to nokia to be fixed,nokia say that when it was last fixed(not by them but cpw)the software was not loaded again properly or checked or tested.nokia have been most helpful,i will update when phone is returned.
:evil: ...Unbelieveble...
😃 Hopefully u will get back your phone not later than 6 months... heheheh... and yes it's a miracle...
Yes,but they will probably send him back the wrong phone..hahaha!!! 😃
Or,if you'll get your phone,they will forget to install some app...ha aha aha!!! :P
Nokia people are so intelligent and know how to do their job!!! :x :evil: :roll: :-?
