Hi all,
Is it possilbe through Nokia PC Suite to access the ringtones that comes with the phone?
Like copying the files to the PC. Many thanks!
Accessing ringtones?
It's possible only if you copy them first from ROM to MMC or phone memory.
ratza wrote:It's possible only if you copy them first from ROM to MMC or phone memory.
OK, ho do I access it then? I cannot access it with the standard file explorer.
Grab FExplorer (best freeware on Earth) from www.gosymbian.com, install it on your phone and then use it to copy the two folders from Z:\Nokia\ to E:\Other\
