My 2GB miniSD showing as 1Gb
3 replies · 2,547 views · Started 22 March 2007
My 2Gb MyMemory House Brand memory card was working fine for about a month,then my N73 had some problems and I lost a lot of my data,and my memory card had to be formatted (phone had to format it).Now the 2gb card shows as a 1gb miniSD,I tried under Win XP with a card reader and I tried an app called Partion Manager,but no luck.Any body got any ideas?
If the card have that same size on N73 and Windows XP, maybe the problem is the card. Try the format of card on XP, with different formats, like FAT and NTFS.
Do u have normal or ME? Cuz som older normal N73 devices doesn't support MiniSD cards bigger than 1G. A firmware upgrade might help, which u might do in a Nokia shop or on internet thru the nokia webpage ... But u'll need the data cable
i had a normal N73,it worked fine on my N73,then done a firmware update with the latest ME software,and the card still shows under 1GB capacity,I think,its just a crappy make of card...
