Wow! Multiple alarms.
8 replies · 3,846 views · Started 11 April 2007
Not sure how this one slipped me by, but at last I can have multiple alarms, something I sorely missed on my N80. I dare say some of you already knew this but I'm a happy bunny and am loving this phone more and more.
(and the battery issue isn't one for me. I'm getting more than a day out of mine (now I've switched off the dual mode, only switching it on when I need some fast internet).
chrsfrwll wrote:Not sure how this one slipped me by, but at last I can have multiple alarms, something I sorely missed on my N80. I dare say some of you already knew this but I'm a happy bunny and am loving this phone more and more.
I can only set one alarm in the Clock app under the Tools menu. Once set, I don't get the option to set another, just deactivate the first one or remove it. Where are you setting multiple alarms?
I've got it on mine, in the Clock app, under the Alarm tab. Click Options then New Alarm, setup the alarm, then you can set more in the same way.
It's one of the icons in the menu, I think it's either in Applications or Tools, I've moved mine and I can't remember which is it's default folder.
HoundDog wrote:I've got it on mine, in the Clock app, under the Alarm tab. Click Options then New Alarm, setup the alarm, then you can set more in the same way.
I have upgraded to the latest v11 firmware and I don't have the facility to set more than one alarm.
OK forget that! I was using the Set Quick Alarm rather than going to the alarm tab and setting it there. I do have multiple alarms 😊
