Hi there,
I am looking to purchase a mem card from emartbuy on eBay (thanks to the vote of confidence from users on this forum) - my only concern is that larger capacity cards will soon be available, 4gb would be nice for music etc.
So If anyone is aware of a time scale for larger cards let me know and I will get a cheap generic card as a stop gap, I dont want to spend �40 on 2gb to find 4gb available for �60 in a few months time!
Many Thanks
This is the one I got, �20 in total, seems to work really well.
http://www.amazon.co.uk/Micro-SD-2Gb-w-Adapter/dp/B000HCGAFK/ref=pd_bbs_sr_2/026-1396832-2936461?ie=UTF8&s=electronics&qid=1176656327&sr=8-2
Sandisks website says the N95 supports up to the 4gb card, but all the previews to the release of the N95 said it didn't, so I would be carefull going for one that big until its confirmed they are supported.
Thanks adz06 - Im sure larger cards will be supported no problem with current firmware (I would guess the biggest card they could test at the time was 2gb?) and deffo with updated firmware. Is there a need to go for the 'ultra' 9mb/sec model over the one you went for? I.E will there be a big difference in loading apps etc
I've not noticed apps running off the card running any slower than from the phone, I have the maps for england stored on it and it only takes the maps program a second or so to load the map of the area im in.
To be honest, speed isnt a big factor for me, but all I can say is it doesn't feel slow, it still takes a few seconds to take a pic though.
crackajack wrote:Hi there,I am looking to purchase a mem card from emartbuy on eBay (thanks to the vote of confidence from users on this forum) - my only concern is that larger capacity cards will soon be available, 4gb would be nice for music etc.
Many Thanks
The buy-now price including P&P and VAT from emartbuy was �30.50 last week and that's for a fast 2Gb SanDISK Ultra II card.
Whilst you could wait for a 4Gb card, expect to pay �60 for the first 3 months it's available.
It's up to you... wait for expensive 4Gb or buy 2Gb now (You could probably sell your 2Gb card on eBay when 4Gb is available and affordable).
Dez
dez_borders wrote:The buy-now price including P&P and VAT from emartbuy was �30.50 last week and that's for a fast 2Gb SanDISK Ultra II card.Whilst you could wait for a 4Gb card, expect to pay �60 for the first 3 months it's available.
Dez
Hi Dez - looks to have gone up to �41 shipped now unfortunately.
If the standard cards arent too bad I think a 2Gb will tide me over until 4Gb comes out and drops in price.
fast 2Gb SanDISK Ultra II card from moby memory �23.99 just ordered mine
I heard... that ScanDisc, DaneElect etc all take much longer to load things up such as apps, photos, videos compared to the genuine Nokia versions...
can I ask what should one do if going up from a 1Gb to a 2 or 4Gb mSD? I mean all the installed stuff will disappear and will have to be reinstalled? or can you back it all up via PCsuite and reinstall it back in the new card? Please suggest, I am new with Symbian, but that is what i would have done in my previous HP 6828 and 6365. Thanks
kostasthai wrote:can I ask what should one do if going up from a 1Gb to a 2 or 4Gb mSD? I mean all the installed stuff will disappear and will have to be reinstalled? or can you back it all up via PCsuite and reinstall it back in the new card? Please suggest, I am new with Symbian, but that is what i would have done in my previous HP 6828 and 6365. Thanks
i believe you could just put your current card in a cardreader, copy all files (hidden files too) to your pc, and then copy it onto your new card. it should work.
From my experience you have to install everything again. this has been the case with all my previous symbina phones e.g. n73, n70, 6630, 3660. Unless sumthings changed with this phone you cannot
menhel wrote:From my experience you have to install everything again. this has been the case with all my previous symbina phones e.g. n73, n70, 6630, 3660. Unless sumthings changed with this phone you cannot
I am afraid this is not the case. I have been copying from one card to another since many S60 generations ago and it works. (Unless you reformated your phone or copy memory card of another phone)
i got one of SanDisk in Bangkok for 1590 Baht (35to US$ or 47to the Euro) and just copied all from the 1GB card to folder in the desktop and copied it all over to the 2GB and it works ok. I also did a back up via the PC suite just in case. Will let you know if anything weird happens.
I’m looking at getting a memory card at the moment so I’ve noted the prices between Amazon and Mobymemory for comparison.
I don’t know if anyone has noticed that a 4GB microSD card has become available on the mobymemory website, it’s a bit expensive but I’m sure it will come down in price over time.
I’ve used the local computer shop in the past and got a cheap memory card (Peak brand :icon13: ), it kept getting corrupted. From then on I’ve always used Sandisk and had no problems at all. Although the first time I bought a Sandisk was of eBay from China and it turned out to be a fake and didn’t work in the phone.
Mobymemory
1GB microSD (Transflash compatible) Sandisk - £7.99
1GB MicroSD Ultra II (Transflash) Sandisk - £9.99
2GB MicroSD (Transflash compatible) Sandisk - £13.99
2GB MicroSD Ultra II (Transflash) Sandisk - £23.99
4GB MicroSDHC Sandisk - £51.99 😮
Amazon
1GB MicroSD Sandisk - £3.13
1GB MicroSD Ultra II Sandisk - £6.70
2GB MicroSD Sandisk - £9.74
2GB MicroSD Ultra II Sandisk - £18.71
The prices above don’t reflect the postage cost and availability (Prices compared on 11 May 07).
*Ultra II transfer rates of: 10 MB/s Read and 9 MB/s Write
4gb one is pre order only
they are expecting stock on 22nd may 07
seems to be the cheapest pre order around, unless anyone else has seen cheaper
i'm getting one of these when they are released
there is a difference though, btw SD and SDHC. Not sure if N95 will take SDHC cards which is what the 4Gb card is
capitaine wrote:there is a difference though, btw SD and SDHC. Not sure if N95 will take SDHC cards which is what the 4Gb card is
The 4GB microSDHC is shown on the Sandisk website combaility list for the Nokia N95. :icon14:
If it actually works properly without any problems is another question, but if it didnt then it wouldnt be shown on the compatibilty list. 😊
Does anyone know the difference between the normal Sandisk microSD and Sandisk microSD Ultra II?
I know that the Ultra II has write 9MB/sec and read 10MB/sec. What does a normal microSD card have?
VJ_UK wrote:
Does anyone know the difference between the normal Sandisk microSD and Sandisk microSD Ultra II?I know that the Ultra II has write 9MB/sec and read 10MB/sec. What does a normal microSD card have?
Normal (non Ultra II) cards are approx 3.5Mb/sec.
If I remember correctly, previous N-Series handsets (N70, N80 etc.), had problems with apps like TomTom if a slow memory card was used.
(TomTom needs at least 7Mb/sec map data transfer speed to draw the 3D display at a reasonable frame rate.)
In some cases apps would stop responding if data was not read quickly enough from the memory card.
Therefore, I would avoid the slow 3.5Mb/sec cards even if they are really cheap.
I use a 2Gb SanDISK UltraII card and have used TomTom Navigator 6 with an N95 with no problems on a 2 hour journey.
�61 seems quite high, anyone found any cheaper that are in stock?
Just marking my interest in this thread.
If anyone does try a 4GB card, please be sure to let everyone know the results.
