DNS settings
1 replies · 3,216 views · Started 16 April 2007
Hello all
New to this forum. Just got my N95 and i love it. I can connect to my wireless router no problems and access files on my PC using the media server. I am however having problems when i try and access the internet. When i try to log onto a web page i get a msg saying Web:No Gateway Reply. I think it might be to do with the way in which our network is set up. After we have connected to the network we the have to enter some DNS settings before we can access the internet.
Is the anywhere for me to set this on the N95 and if so can i set it just for my home connection?
Thanks for any help you can offer.
Steve
if you have to set your DNS settings manually on your home network you'll have to do the same on the nokia. i think its under advanced settings. if you don't know your ISP provided one - try 158.43.128.1
