ok i have a n80 so no abit abouwhats what i have done the ie thing on about 3 n80s me n some n70s but i cant get the code to change on the n95 via nss also nsu wont help get rid of the vodaphone shit.. any ideas?
also truphone will intall ect but then no internet call option is this the rippling by voda on the VOIP??
what to do struggle on or find another provider? i dont really want to change the prduct code to void the warrenty then it to naff up say on a upgrade as many n80s hae been oing so and then him to be left with a nice n95 brick??
SURELY THIS CANT BE LEGAL?? freedom of choice and all!!
who has a unbranded or a least a voip usable n95/?? who are you with
were in UK BTW
does the slider not answer call or hang calls up?? if so wheres the option??
last thing is will n80 apps install on the n95 as it doesnt seem so
thanks for all help
bbracer16valver wrote:ok i have a n80 so no abit abouwhats what i have done the ie thing on about 3 n80s me n some n70s but i cant get the code to change on the n95 via nss also nsu wont help get rid of the vodaphone shit.. any ideas? also truphone will intall ect but then no internet call option is this the rippling by voda on the VOIP??
were in UK BTW
thanks for all help
I'm not in th uk so I have no way to tell if using fring will do your VOIP or if the issue is more substantial (dark powers at work on the service provider front)
I've installed fring because it supports skype, msn etc.:icon14:
The obvious test is to use a wlan connection - get fring working on that.
Then test it on your provider connection.
Good luck! 😊
fring is not a option i dont like or trust the software
Sorry, slight thread-jack but why exactly don't you trust Fring? Do a forum search and you will probably find out that it is because Vodaphone have essentially removed your ability to use VoIP that is at the root of your issues.
Dude, your mobile phone is worth more than your car lol!
LouieCoop wrote:Dude, your mobile phone is worth more than your car lol!
Lol, Low blow!!! I have an N95 that Vodaphone has "altered" (Read: Crapped up!). and i can use fring fine. I think its a gr8 little program
i dont have a n95 my mate does (there worth about as much as a broken mirror)
fring i had on my n80 it was poo (carry on with msn and truphone much better - whooops most of you wouldnt no :tongue: )
as for the car it worth more than any stupid phone and has alot better features 😉
www.retro-renault.com 😉
I have some broken mirrors that I will sell to you for £300 each, cheaper than a N95. Please get in touch immediately....
