Emoze on N95?
4 replies · 4,699 views · Started 07 May 2007
has anyone got emoze to work on the n95? i haven't been able to get it to work on mine (i never receive the SMS).
i checked with tech support and they said something like the n95's version of symbian is not yet fully-supported.
i'd like to use it with my gmail --so if anyone can give quick instructions on how to make that whole she-bang work out, it'd be greatly appreciated.
thanks,
emoze will actually send you this link:
mobile.emoze.com
i checked but i get "This service is not supported by your device"
I had the same problem, but now it works perfectly!!!
Just choose devise N73 ....
Choose download client and install the file with pc suite ...
It will work!!! :icon14: Enjoy.
Forgot to check if outgoing mail worked😡
And is doesn' t work. You can receive email but sending an email will be for now a problem. The Support of Emoze told me that they are working on this problem. It has something to do with symbian version 9.2 ... but that could not give me a timeframe when it be will be resolved.
:icon13:
Yes, Emoze is acting a little weird with N95 but it does work with outgoing mail aswell. I'll explain how.
If you try to choose "create email message" in your message application your phone tries to open it's built in email client, right? Even if you open the new emoze folder created in your inbox, the same thing happens.
But, if you place emoze as one of your 6 "active standby apps" on your standby screen, you can send email from there. There's two emoze to choose from in "Settings/General/Personalisation/Standby Mode/Active standby apps/". Choose the first one called Emoze and exit.
Now looking at your standbyscreen you have a folder called Emoze. This is Emoze own folder, that was created during the installation. From this folder you can just choose "create email" and Voila!
Enjoy emailing with emoze! 😊 You can also from here just choose "Reply" after reading a mail.
