Import / Export SMS messages
2 replies · 10,114 views · Started 09 May 2007
I've searched and searched and can;t find an answer to this. I usually run a WM5 device but for various reasons I need to swap to a 6680 temporarily. I need to be able to transfer my SMSs from the 6680 either to Outlook or to a csv file. I can't find any software that would do this. Any ideas? I also need to retain the sent / received time and the phone number details.
If, 6680 is supported by PCSuite 6.82 (avoid 6.83) - search on Nokia Site for that - than is just use the export command of messages menu on PCSuite.
Thanks - I had in fact ignored PC Suite as it's usually so bad!
Unfortunately, that doesn't deal with the issue. I had hoped to be able to import the messages into Outlook and then use Jeyo to export them to my PPC (which is the ultimate goal).
Unfortunately, I can't successfully import the csv file (including the SMSs) into Outlook and therefore am back to square 1. Jeyo don't have a symbian version (so I can't the messages directly into Outlook) and then out again.
Is there any other way of doing this - getting SMSs from a 6680 either to Outlook or directly to a PPC? There must be a way!! Help please!!!
