is it possible to install tom tom on the n95 ??? and use the gps for free ???
sat nav
You can indeed load TomTom onto the N95, I have it running on mine, only problem is at the moment it cannot see the internal GPS........awaiting a patch from TomTOm that will enable the use of the internal GPS.....
