Is all programs operating at Series 60 will work on Nokia E90 ?
I have a question about software for E90
Good question.
All S60 3rd Edition and S60 3rd Edition Feature Pack 1 apps should work. No older apps will, for sure.
N/A wrote:All S60 3rd Edition and S60 3rd Edition Feature Pack 1 apps should work. No older apps will, for sure.
How does the several apps make when we switch between internal and external display? Those apps must be prepared for E90?
It's allmost there!!!
From my experience, not all software works with e90. Even though they work on n73 or e61i.
Lastly, does any one has blackberry for e90 yet?
Read my post on Issues with E90. Some apps will crash on E90 surprisingly, but most of S60v3 should works fine.
Some apps may not display correctly if you use the apps in front display then changed it to internal display e.g. Nokia Business Center, Profimail. Other than this I did not find anything of significant.
Hi aylmer,
I'm not sure if you already have the answer to your inquiry but this will give you the latest BlackBerry release for the Nokia E90 Communicator - http://www.businesssoftware.nokia.com/blackberry_downloads.php.
FYI. Thanks.
aylmer wrote:From my experience, not all software works with e90. Even though they work on n73 or e61i.Lastly, does any one has blackberry for e90 yet?
