Advise
7 replies · 4,041 views · Started 16 May 2007
I do appreciate some advice of someone more experiment with these technologies.
I will try to explain my problem.
My previous equipment was: a Palm LifeDrive with Tomtom GPS software, an IR keyboard and a Nokia 6234. Then I have bought a N73 and start using the Tomtom software with it. In a few days, I drop the LifeDrive and the 6234 and start using the N73 as mobile, GPS and PDA (and also as photo camera). But with N73 is not very easy to input a lot of text.
What I would like to know is, in your opinion, E90 can take the place of all me previous equipment?
Thank you for your help.
The LifeDrive can be slow for certain tasks. The E90 should be more consistent and has about 79MB of RAM as opposed to 10MB on the Lifedrive. I have not used an E90 but I do have a 9500 and Lifedrive and the 9500 can be quicker for data entry and more compact then an additional keyboard. Also, it appears that the E90 may be able to support 4GB cards but can definitely support 2GB - so not as good as Lifedrive.
jah wrote: Also, it appears that the E90 may be able to support 4GB cards but can definitely support 2GB - so not as good as Lifedrive.
Where did you hear/read that?
Thank you for your answers.
What about the daily use? In my job i have to write a lot and some time standing up, is it easy to write like this?
How can we store information like a diary?
In a way that it stays allways there for consulting?
Thank you one more time!
Yes, I think the E90 would suit your needs very well. Yes, it's very easy to type standing up, I've tried - with two thumbs. Or one handed using the cover phone, of course 8-)
There is only 1 draw back, E90 is slightly heavy, nothing to complaint though since it packs too many feature 😊 I love it, but if only it could be slightly lighter.
After a couple of days using E90, I think it is a great phone! Yes, it is a little heavy, but that is ok considering that I will not take the PC on my 2 or 3 days travel.
