Why Not on Symbian?
2 replies · 1,113 views · Started 19 May 2007
Befor i bought My mobile N95. I had a windoes smartphone. it was old but it could do what no symbian phone could wich is reading and writing to major langueges Arabic & Chinese (in the whole System not only SMS). Every one was asking me how i did that. it was very simple i just added chinese font to my memmory card and wala magic happened.
Before i bought this phone N95 every one told me that if my shxxxxty Win smartphone can do this then symbian will have no problem at all. well i guess my Win smartphone was not so shixxty after all.
I have looked for a font tool that will enable me add a font in the system or even in the MMC I found somthing cooled fontrouter that i only found in the chinese websites mainly.
So if anyone noes anything about his program or anything else please reply.
Regards
Hi there, I think the easiest way is to change your product to the chinese one. Then do a firmware update. I did. And since all updates have english, you get the two languages.
I found some programs to read Arabic, but unfortunatly I can't give you the link. (Forum Rules). But If you google around abit, you'll find it.
This way you could write English and chinese, and read Arabic.
There is also some programs to change fonts out there but most of the ones I found has been homebrew that I haven't been willing to try. NOT as easy as it's on a WM.
Good luck!!!
rooster80 wrote:Hi there, I think the easiest way is to change your product to the chinese one. Then do a firmware update. I did. And since all updates have english, you get the two languages.
Good luck!!!
Please note that my phone is already chinese i want it to read arabic.
