I'm trying to transfer my web bookmarks from an E61 to the N95. A transfer via bluetooth didn't do it... and PC Suite doesn't have any options either...
any ideas on how to do this? :frown:
Hi again Capitaine,
In Nokia PC sync, there's an option to sync your bookmarks aswell as your contacts, calendar, notes and to do's.
Hope that helps!😊
I think the transfer application on both phones also can handle that.
rooster80 wrote:Hi again Capitaine,In Nokia PC sync, there's an option to sync your bookmarks aswell as your contacts, calendar, notes and to do's.
Hope that helps!😊
and in fact, you can't even do this with the E61 - transferring bookmarks off that phone is not supported through PC Suite
as far as I can see, there is no way to get the bookmarks off the E61 to the N95
If you use the Transfer app, then its just one-way traffic: only from the N95 to the E61! It wouldn't let me do it the other way around... no idea why...?!!
