1. Is there another format you can look at your gallery instead of the circle format?
2. I have images in my gallery but it also show other images like my tomtom icons?? Anyone know how to point the gallary as a specific folder?
3. Also I have had a problem with a video I did, sometimes it plays on the phone ok and sometimes there is just a blck sceen? anyone else had this problem?
4. When is the next firmware available from Nokia?
MrRed wrote:1. Is there another format you can look at your gallery instead of the circle format?
You can use the File Manager, Menu | Tools | File mgr.
MrRed wrote:I have images in my gallery but it also show other images like my tomtom icons?? Anyone know how to point the gallary as a specific folder?
I've also got tomtom on my phone. If you activate "Data Transfer" mode for USB then connect your phone to the PC using the USB cable. Then using the PC you can right-click each picture, choose Properties and tick the Hidden box. The Gallery then won't see them but tomtom still will.
MrRed wrote:1. Is there another format you can look at your gallery instead of the circle format?2. I have images in my gallery but it also show other images like my tomtom icons?? Anyone know how to point the gallary as a specific folder?
1. You can use the built in file manager or a third party one like Y-Browser
2. Have a look in this thread I made http://www.allaboutsymbian.com/forum//forum/thread/60026/&highlight=hide
3. That may be a problem that there isn't enough RAM to play it back. Try turning off and back on and then doing trying to play the video before running any other apps.
4. The current firmware is 11.0.026 and no newer firmware has been announced yet. Keep checking the sticky thread http://www.allaboutsymbian.com/forum//forum/thread/58226/ for the latest firmware news
Thanks for all your comments..
Where do I get 11.0.026 from? When I use the nokia updater it tells me no updates available and I am still running 10...etc.
