Hi all,
Does the N95 support SMTP authentication?
Many thanks,
Christian
Question about email client
Christian_1 wrote:Hi all,
Many thanks,
Christian
From what I understand it does (..not an expert on the area..). You can configure specific username, password, security ports (StartTLS, SSL/TLS or "Off"😉 as well as specify port to use for smtp.
The options are the same as for POP3/IMAP, e.g. you can configure POP3/IMAP and SMTP individually.
Helped?
