Nokia N95 and Map Loader
2 replies · 4,874 views · Started 24 May 2007
Around 2 days back i have downloaded India map using Nokia Map Loader into memory card. And from then onwards I have been trying to figure how to using Maps application with the downloaded Map. So, my questions are
1. Where the map is downloaded?
2. How to enable Maps application to use the downloaded map.
I believe the map that is downloaded is for static use and i can navigate through the whole map without internet connection.
Could you please suggest some tips.
Thanks in advance
Kalyan
kalyanvgopal wrote:1. Where the map is downloaded?
The maps are held on the memory card in the Private\20001f63\diskcache folder, but this is only accessible either using a PC in 'Data transfer' mode or a third party file explorer on the phone. Also the files in that folder aren't recognisable as maps.
kalyanvgopal wrote:2. How to enable Maps application to use the downloaded map.
You don't need to enable it, if there's a map downloaded the program will automatically use the stored map.
