Flashing text symbol
4 replies · 3,219 views · Started 24 May 2007
hey, i used the search but couldn't find what i was looking for so sorry if this has been posted before but...
yesterday the text message symbol, tht in the top right hand corner when you have an unread text message, was just flashing on and off and been doing it constantly for a whole day now. I thought it may be becasue my memory was ful and i had to delete some texts but this didn't solve it. I had a quick browse of the phones handbook but nothing is mentioned in there, and im just curious to know why its flashing lol, anyone seen this before?
it doesn't seem to be affecting the sending or receiving texts either :con?
cheers.
Maybe try rebooting the phone. That little icon usually means that your message box is full but since you said you deleted some messages it should have went away.
It probably means the text message memory on the SIM card is full. That would be separate from the memory on the phone, which would be why it still flashes even though you emptied the phone memory. Go to messages, options, SIM messages and see if there are any messages there
