hi could anyone tell me where to find the root of my memory card ,i'm trying to install something and it tells you to install part of it to the root of your memory card ,can anyone help plz ,
help
The root of any drive or memory card is the top level folder, IE the screen you first see when you open any drive or memory card, before you go into any of the subfolders.
so when i go into file manager on the pc suite and it shows you 4 icons PHONE MEMORY ,MEMORY CARD,CONTACTS,MESSAGES,is the root the memory card icon or do i click on memory card where it shows another group of files at the top is the attachments folder , is the attachments folder the root, :con?
You go into "Memory card" and that is the root folder of the memory card.
Nokia Phone Browser\Nokia N95\Memory Card
You have folders in the root called (amongst others) images, sounds, videos...
