Can 7650 record movie clips? if yes, does the original software is capable of it or need to download or sumthing?
7650 & MP4
there isn't any app. that will allow you to record in mp4.(wait for 3650)
but you can watch downloaded clips using realone player
You can download video records apps that will record MP4 video but not from here. A company called Hantro wrote the most popular program, but they sell only to operators.
If you really want the app, you're going to have to do some searching on the WWW.
Oh, and by the way. Video and MP4 has been discussed an awful lot on this board. It might be worth searching before you post as most answers can be found quite quickly...
Andy
Yes the name of the appl is called T-Mobile Video Messenging. It's a very cool and handy appl that allow 7650 to not only act as a digital cam but also a video cam.
Only limitation is the qty of the movie and also it only allow 12sec of film time due to low memory space.
didn't know 'bout that app....sorry
and Edgedale thanks for the info
There are couple of apps the will allow video recording.Some of them even allow audio recording too (Winds VideoMMS).
There is one problem.They are available trough operators only
Ex: VideoMMS is for italian operator users and T-Mobile is for German and Hungarian operator users as far as i know.
Allso there is pocketvideo on whick VideoMMS is based on (Not sure about this)
2 programs i know of. 1 is videomms and hantro. i have them both. videomms is better since it has audio recordin as well. and not its not compulsory to b a wind subsriber to have it . 😃
yes, winvideomms allow to record audio but that's only add in after u have recorded your video. I hope there will be one that can allow u to record video and audio at same time while allow you to have the option to edit the audio later as well.
I would expect video with synchronised sound to be out of the 7650`s processing capacity, not to mention the space each short clip would use. The tMobile software takes clips of up to 12secs, on about 90kb. If its of a well lit subject, with plenty of motion, the time drops to about 6-8 seconds,as mp4 compression struggles. We would be juggling our memory all day.We await the 3650, got to be about perfect....unless the 7650i appears...... :angel:
where can winvideomms be downloaded?
If you are Wind customer in italy then from their site. It costs some cents to download it.
If not, then there is no way.
Look in the 7650 news section for the link.
[quote="Jesal"]2 programs i know of. 1 is videomms and hantro. i have them both. videomms is better since it has audio recordin as well. and not its not compulsory to b a wind subsriber to have it . 😃[/quote]
Yes it is,any other way of having it would be illegal.
