I cant seem to find out how to change to Line 2 on my N95...... I've even consulted the manual, and still no answer! :frown:
I've just phoned my line 2 number and a voice message comes up saying "This service is not compatible on this line"........ I'm guessing N95 can't do Line 2? Is that correct?
Anyone know anything?
Thanks:icon14:
Try a long press of the '#' key when the phone is in the standby state.
N/A wrote:Try a long press of the '#' key when the phone is in the standby state.
Thanks, but I've tried that.... All it does it change it to silent.
Could it be because I have upgraded my firmware?:con?
If you were on an Orange firmware, and moved to a generic product code, then the firmware upgrade will have removed Line 2 support from the phone - generally (for the UK at least) you need to be using the Orange firmware for Line 2 support.
I have since found a generic code of 0548364 which has line 2 support 😊
