N73 TomTom problems and Master Reset issues
6 replies · 7,353 views · Started 12 June 2007
I've downloaded TomTom 6 for my N73. Basically I installed it once and it was all fine and the program installed and I started to go through the process of configuring it all correctly, then I realised I hadn't downloaded all the program correctly, so I did just that again, got it all and now when I go to put it back on my memory card it won't even install... The guy who I got the torrent off told me to master reset and I don't even know how to do that so I'm just wondering if anyone here can help me reset it safely...
regards.
Firstly, you need to read the rules regarding posts about warez.
Secondly, put your hand in your pocket and buy a legitimate copy.
Why do people insist on using warez and then bitch when it doesn't work ??
lovesign wrote:Firstly, you need to read the rules regarding posts about warez.
i wasn't bitching... I was merely asking if anyone had a clue as to how to master reset my phone so I could try again........... Firstly, get a clue. Secondly, I'm skint so pretty much anything downloaded is a bonus. Thirdly, grow a dick and some balls and go see how your filthy mouth stands out at people in REAL FUCKING LIFE.
suck a dick.
Big words for a little boy !
When you're skint, it usually means you either don't buy stuff or you save up until you can afford it. Sadly, chavs like you now add "Steal It" to your list of options.
Mate, if you met me in real life you'd be eating those words before you spat them out of your little Elizabeth Duke festooned gob.
Get a life, get a grip and get the hell off this forum.
You see, you can abuse some one with real english words and not even need to swear or make weak sexual references 😉
As for resetting, use the search facility. Do some work. I know, it's a foreign concept to people like you who steal everything they own, but try it, it's fun.
Great words!!!
Because people work to make software, I paid for the software I use!
If everybody make this the real world, it could be a little better!
Steal is a crime everywhere in the world.
