N73 screen pblem!
2 replies · 1,866 views · Started 13 June 2007
Hello 2 everyone, I've notice a screen problem with my N73, I've try to
look through threads, but think my problem is completely different i.e.
I use to scrub my screen with the cloth I've got, when I first bought it
6months ago, I note that just in the middle the size of a thumb my screen
goes as if one is toughing an LCD screen with grey/black ink! I only
though it the pressure I've applied on first, but each time I clean it,
the liquid appear and vanish in 1sec or 2sec! Is it normal or my screen
would be dead just after the next 6 months where my warranty would b null!
Thanks 4 caring to reply. Nice day to all!
Apply a little bit lower pression on the display. The plastic cover touches the creen and you might wreck it for good.
If your N73 is in the warranty, try to replace it! That is not normal. The plastic cover should not touch the screen.
