what settings are people using and do i need to enable pop forwarding in gmail or is it set up?
cheers
cheers
hey there
yes indeed you need to activate your pop by goin to the "Forwarding and POP" seetings in your gmail account.....as far as your phone is concerned..you need to call your local subscriber and they wll help you as far as the phone settings are concerned....its quite simple and takes barely 5 minutes to activate....
i am using a E61i myself and accessing gmail on it...if you need further help do lemme kno...cheers
Ignore the fact that this is instruction on how to setup Outlook...... It still gives you the server details, and the port numbers, security settings etc.....
Steve
thanks a million that did the trick
