Hi everyone,
I just bought a 'Super Ghost SIM' from eBay, it cost �4.32, including postage to the U.K.
It allows you to use 2 SIM cards, on any network (assuming your phone is unlocked). It's best feature is that you don't have to reboot your phone to switch SIM's, you just go into the 'Dual SIM Card' application, under Menu\Applications, and you have the option of both installed SIM cards (it displays their actual phone numbers in the list).
You select a SIM from the menu and it takes between 10-20 seconds to completely switch, which isn't too bad. It also has an option to auto-switch every 3-99 minutes, which is also very handy.
To fit the card into the N95, you have to do a little differently from the instructions, however.
The manual tells you to place one card into the SIM card slot on the phone, then install the battery, then lay the other SIM atop the battery, and replace the cover. If you do this on the N95, you'll have an extremely hard job getting the battery cover on without snapping it. Also, when you DO manage to get it on, the cover itself loses its 'flatness' and no longer sits flush with the phone casing. It looks like it may snap off very easily.
My method is this:
Install the SIM, and the ghost SIM into the SIM slot on phone (as per the instructions).
Then fold the second SIM over, UNDERNEATH the battery, and as low to the bottom of the phone as possible. Then slot the battery back in, and press it down hard, whilst sliding the cover back on.
This leaves the cover about 1mm out of line from the phone at one end, but it feels a lot more secure, and less likely to snap.
This is a great product and I just thought I'd share that with everyone, if anyone thinks this was a pointless or useless topic, then feel free to remove it, and I apologise
Thanks everyone!
Andy
